some ideas please
Old Feb 12, 2000 | 11:51 PM
400rider's Avatar
I recently got my 400ex, and I am pleased with it, but more is better especially with power. I have spent a lot of time reading up on hp mods,more specifically those which do not get into the motor, like pipe, jetting, air flow. After a LOT of post-reading, I am confused and a little disheartened. If a simple mod to the stock pipe, XR 400 tip will give the increase as well as an aftermarket pipe, why spend the money, and sacrifice sound? If the 400 head flows more air than the motor needs, why jet or modify the airbox? It sounds like the best value for the money is more cubic inches. Would I then need to reconsider and go for the other goodies? Am I way off with all of this? Some suggestions from you would be great. Thanks John
[red]Note from atvbbs:If you desire a reply from a specific person, please use the e-mail function to contact that person.[/red]
Edited by atvbbs
Old Feb 13, 2000 | 12:31 PM
trx430ex's Avatar
400,Rider
It seems that things are changing as fast as you get the first mods figured out. Then you find out something new just cropped up that make your first mods archaic.
I understand your confusion, My LRD header and slip on is only 6-months old. And now I find out that it has been updated again to be even better.
I don't mind, Everything must evolve. The one piece of advise that seems consistent, That I can give you is. New pipes and jetting kits make a world of difference. Done right, the quad will feel almost twice as fast as stock. A couple gearing tricks can't hurt either.( ie- set it up for where you ride).
Pam is pretty good isn't she. She has made me do a Tim Allen, Aaarrhhuuuuuaa. From time to time. And "99-forum awards" winner - Milk carton member.
Note to atvbbs, Please conform to forum guide lines regarding "fonts"/colors
Old Feb 14, 2000 | 01:36 AM
hot_shoe_cv's Avatar
I believe that the admin. is conforming to guide lines. If you will look in the reply window you will see the box below, which should explain it to you.
View the CFB Code Guide here
fordfaithful21
Dec 7, 2015 05:52 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
