spilting case's honda 250r
Old Mar 26, 2002 | 11:32 PM
Ohio250rlover's Avatar
just woundering how to do it, what tool's are needed and over all how hard is this to do. given the price shop's charge for it im sure it's no 5 minute job, so if someone could tell me an easy way to do it...or should i say as easy as it can be made,iv heard of the r engine alot of stuff just falls out more so than most engine's is this true, and can someone also warn me of anything to watch for or do while im doing it byond the comman sence stuff thank's
Old Mar 27, 2002 | 12:19 PM
LT80's Avatar
LT80 Expert
They make a tool to split the cases.I have been lucky I guess,as mine slid right apart and needed no tool to split it (twice).It's the tranny components that can fall out.If you have doubts,have no one to help thats done it,can't understand the book (I cant),maybe you should have the shop do it,,but you can do this!! I looked and looked till I figured it all out [img]i/expressions/face-icon-small-smile.gif[/img] good luck
Old Mar 29, 2002 | 01:08 AM
sweet lt80 my luck is always been bad so i doubt the cases are just gonna ssllliiddee apart for me could u go into some more detail on takeing it apart and whats the best way to minuzie part droppage ...anyone give me some input i help ton's of people on this forum now im in need of the help let's see some replies
Old Mar 29, 2002 | 11:28 AM
retro's Avatar
Just make sure ALL bolts are out of the cases. You will need an impact wrench for the large 27mm nut that holds on the clutch basket and the flywheel nut. You will also need the correct flywheel puller, NOT a gear puller! Also, DON"T use a screwdriver to pry ANYTHING apart!
ERIC
Old Mar 29, 2002 | 10:42 PM
THEMOOSE's Avatar
Get a clymer manual & read it a couple of times & then read each step as you do it. If you follow the directions you can do it, I did. Just make sure you lay out all the parts as they came out, especially the gears as there is a lot of spacers & such that need to be reassambled correctly.
The main tricky part is knowing which case half to lift off & which side all the gears stay in on disassambly pull the wrong half off & all your gears fall out & it's twice as hard to do.
Get a manual, read it & follow along step by step & it can be done.
Me & a buddy (it does help to have an extra set of hands) had it apart & together again in an evening (about 5hrs) Not including pulling it out & putting it back in the frame.
The 250R is realy one of the easier motors to work on.
Old Mar 30, 2002 | 02:11 AM
thanks man i already have the good book and its already down to the cases i just need to split them any tip's&tricks guy's...i hate to pick your brains but this is a big deal and i know many of you know stuff not found in a manual ANY OTHER HELPFUL TIP'S? thank you
Old Mar 30, 2002 | 02:26 AM
THEMOOSE's Avatar
Look over all the gears real good not just the bad ones. An 86 has probably had a long hard life so check everything very carefully that way you won't have to split the cases 6 months from now.
as for tips it really helps to have an extra set of hands when splitting cases. Split the cases slowly & carefully to keep the gearsets intact this makes it much easier to reassemble when you take them apart & see where every thing goes.
One more thing, after splitting the cases look in the case halves for washers that may have stuck to them.
Good luck!
Old Mar 30, 2002 | 11:25 AM
LT80's Avatar
LT80 Expert
I'll add:: it helps to lean the motor on the shifter side (clutch side up) and remove the cover.
going together tip: make sure that the motor is NOT leaning on the shift shaft,if so the shift shaft can come off the lil things that it pushes on,then you have to take the cover back off and put it in place,no big deal,but maybe you can avoid this [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 30, 2002 | 04:28 PM
thank's to all of you im very greatful for all the input, if anyone as anything else to add please do so im about to crack it open in a few days iv just been gathering every tid bit of info on the subject i can find thanks guy's
SDR-II
Sep 29, 2015 01:06 AM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
