Cylinders on TRX250R
Old Apr 6, 2002 | 01:32 PM
LiveWire's Avatar
I relieve the bridge on my FL350R cylinders with a flapper wheel on the air grinder. I tilt the grinder at an angle one way then the other and do this from both ends of the cylinder. This gives me a cross hatching on the bridge. I check the depth by bending a feeler guage and putting it across the center of the bridge. I then put a straight edge across the feeler guage. If the straight edge rocks rocks on the guage, I have not removed enough. I use .004", but the FL350s run hotter because of being air cooled.
Old Apr 6, 2002 | 06:22 PM
racer425's Avatar
Is this common on the 86 model ? I have had trouble with ring wear on the exhaust side ever since it was bored . I was told the cylinder was shot and needed replaced because of the ring wear . I check the wiesco piston and it does not have the holes lined up with the exhaust bridge . What do i order for a piston to get these hole as this makes alot of sense to me as i can get 4 motos out of it before low compression . Lastly i have been thinking of changing to a pro-x piston would they have these lube holes ?
Old Apr 6, 2002 | 06:29 PM
2fun's Avatar
As was mentioned before, a person can relieve the bridge.
The bridge heats up faster, because it is so thin. As it heats up, it expands, and sticks out into the cylinder causing undue wear.
A good motor builder will relieve this area as part of his bore job.
Old Apr 6, 2002 | 07:03 PM
THEMOOSE's Avatar
You can drill your own holes in the bridge area of the piston. I don't rember the size drill to use but I think the instructions are included with Weisco pistons(or at least they were) I sold my 250R so it's been awhile since I did mine.
Old Apr 6, 2002 | 07:38 PM
  #15
racer425's Avatar
Thanks for the help all i will try this it may save me some $$$$$$$$$$$$$
Old Apr 7, 2002 | 04:36 AM
  #16
THEMOOSE's Avatar
Your welcome & good luck
Old Apr 7, 2002 | 09:46 AM
  #17
LiveWire's Avatar
I drill my own holes. I drill two .080" holes centered at 3/8" and 5/8" below the lower ring groove. With a bit that small, it will flex and walk around. You need to start it with a centering tool first.
Put the piston on the rod without the rings and lower it on. Put a felt tip marker through the exhaust port and draw a line on each side of the bridge. Pull the piston back off and drill the holes between the lines.
A small amount of mixed fuel will go through these holes from the crank case. The fuel evaporates cooling the bridge and leaving the oil behind.
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
