what would cause a high pitch whisle or wine from a new Polaris Sportsman 500
Old May 27, 2002 | 11:19 PM
hotdog's Avatar
noticed a noise like a high pitch wine or whisle coming from my bike.. while driving it...Did not notice it before ..Anyone know what it could be....thanks
Old May 28, 2002 | 01:26 AM
Blazer250's Avatar
What speed does it do it at? Does it do it when you rev it up in neutral?
Old May 28, 2002 | 03:21 PM
hotdog's Avatar
It makes the noise when you and moving,
Old Jun 12, 2002 | 06:35 PM
fruitjacket's Avatar
It's probably the engine braking unit.
Does the pitch of the sound get higher as you go faster and lower when slowing down?
If so, that's PROBABLY what you're hearing, but it could be numerous other things including bearing(s).
Old Jun 12, 2002 | 11:17 PM
Need4Speed's Avatar
I've seen a lot of Sportman 500's with the same thing you describe. So far every one has had a dragging back brake. I always pop off the caliper and pull the pads off. I spray a little bit of WD-40 on the piston in the caliper and it seems to take care of the problem. The whole process takes less then 5 minutes.
Old Jun 20, 2002 | 04:01 AM
Alaskanredrider's Avatar
the cat you ran over?
neilbedwell
Nov 10, 2018 11:02 AM
coldnorthpol
Jul 14, 2015 11:22 PM
yellowpolaris
Jun 21, 2015 11:13 AM
kevbowe
Jun 1, 2015 01:17 AM
May 27, 2015 11:15 AM
