'00 Wolv carb?
Old Apr 3, 2000 | 12:30 PM
MDP49's Avatar
I have a '00 Wolverine that I got WET a while back. Immediately after that, I changed the oil several times, drained the gas, etc. Since then, while cruising along in a higher gear at low rpms, if I push the throttle closer to wide open it will sputter and cut out. Once the rpms get higher, it seems to do fine. It doesn't always do this, but most of the time it will. And it still seems to be cutting out if I climb alot of steep hills. Thanks for any ideas.
Old Apr 3, 2000 | 05:18 PM
ATC350XinIL's Avatar
Carb needs cleaned more than likely. Slow air jet might be dirty. Take off the carb and check it out.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
