Smoking 440ex when first started
I have a 440ex kit installed with the wiseco 89 mm piston. I had the cylinder bored at a very experienced shop. Well when the engine is first started it smokes blue pretty good. Then when i warms up it stopps completely. I broke it in like i was suppose to and have been running it for a little over a month. It has been threw several tanks of gas now. It still smokes when cold but not once when warmed up. When i had my stock bore it never did this. Is this normal or do I have a problem. I run mobile1 motorcycle oil.
My brother's 440 is doing the same thing, and his is about 3 months old. I assumed the shop that did his put in new valve giulds/seats but i'm not sure.
could it be anything else??? NO, ....I was afraid you say that.[img]i/expressions/face-icon-small-wink.gif[/img]
BIggerisbetter.
BIggerisbetter.
I know that a 440 will burn a little oil, but we only see it in the oil tank being a 1/8 qt low after 2 rides, never any smoke. Mine and my buddies don't smoke, and we both have bigger valves, guides, Ti springs and were both from a different builder. Suspect valve guides, rings, or boring.
Good luck
Good luck
