Help with 400 scrammy topend
DON"T blame her!! Smart woman! If yours is fixed right,the engine should last for years! Like I said,I've had guys try to get by on a top end only,but ended up having to tear into the bottom end. This area requires special tools,and its best like you said let the dealer do it for you. Good luck on the repair. OPT
Well when it rains it pours. I started it up again and let it idle while I backed my truck up to load it in the back. Off to the dealer to find the knock. I put in gear and pushed the throttle to drive it and the quad didn't even move yet and I heard a metal pop and it died. Won't start and feels like low compression. Going to pull motor out and send to Rick Ritter for a complete
Overhaul. Top and bottom. He thinks maybe rod bearing since old piston skirt was worn and possible broken ring this time. Sometimes i wonder if it wasn't for bad luck I wouldn't have no luck at all.
i got the 400 xplorer4x4,...first real quad!! an i love it!!! i run with 650 v-twin kaw's an he cant get away from me sept for open range outta the hole!! put it in thick red clay mudd over tires today an the quad loved it as much as me!!not sure what a scrammy is but this 400l 2smoke is a good mid size motor!!dont give up on it,...itll be worth it all when your kickin up mudd!!!
