Rear end Grinding on my 700 Sportsman
This does not happen most of the time, but there are times when I take off after having shift from any range to High or Reverse, my rear end grinds when I it a little throttle.
Is there an adjustment I can make or is this the start of far worse problem, like replacing my rear end.
I am planning on taking it to Colorado elk hunting and want it in top condition when I leave.
I have done a ton of work to my 2003 Sportsman 700 since I purchased it last December and it's to late to turn back now.
Old Polaris Tech, you are probably correct in saying it could be the transmission. It sounds like it is right under the seat. If it is the tranny drive shaft free play, what can be done at my level? What parts need to be replaced? Or should I take it to my Polaris dealer to have the work done?
I changed all the fluids with Polaris branded oil and lube, but this problem was happening before I purchased the quad.
By the way, you are right. The rear end does take 5 ounces.
would the pull up to a brick wall/tree and give it gas test work on this atv? I remember you suggesting that to me in order to check the silent chain, just don't know if that's an "across-the-board" test or just certain bikes.
Usually worked on the ones that the chain was really worn out with me. Would grind and slip against a post. Worth a try any way. OPT
I wasn't as clear about the problem as I should have been. It only happens occasionally, but it is when I am shifting into High or Reverse. It will go ahead and snap into gear when the grinding stops. I worked and planted two food plots over the weekend and it only happened twice. It seems as though it grinds worse when the shifter is not quite in the correct position.
I will have it checked out after I adjust the linkage.
FYI: My inside CV joint just went out tonight while disking this evening. I jacked it up and put in gear and only the rear right wheel turns. So I will be placing an order for one tonight. Any suggestions on who I should order from? I heard CV man was a good place to start or should I just a Polaris OEM?
