Troubles putting on rear caliper/rotor/sprocket
Old Jul 28, 2011 | 06:43 PM
hokyscrambler's Avatar
Default Troubles putting on rear caliper/rotor/sprocket
I bought ATV with out rear caliper, rotor, and sprocket. I got all OEM parts I'm having problems installing rear caliper,rotor and outer sprocket. I can install rotor and sprocket but caliper won't go on and there is a gap like shaft isn't long enough. I can install caliper and rotor but not enough shaft for sprocket. Shaft isn't broken because it has original numbers on outside tip. Is the 4x4 worth the hazel ?
Old Jul 28, 2011 | 09:59 PM
First thing if you don't have a manual is to Google PURE POLARIS PARTS CATALOG,click on BROWSE and bookmark this page! You can look up your machine and see if you have all the parts needed and will show how it goes together. Try this and see if it helps,then get back to us if you still have any problems! OPT
Old Jul 29, 2011 | 12:41 AM
I forgot to mention that the ATV is a 1996 Polaris scrambler 400 4x4. I have looked at the parts diagrams and i have a haynes manual but it doesn't tell me much. Does any one have any good manuals to download or any ideas?
Old Jul 29, 2011 | 05:37 AM
If you can install the caliper and rotor on the shaft but not enough room left for the outer sprocket,sounds like you need the caliper piston to go further in which will push the rotor farther on the shaft.Then there is a circlip that goes on the shaft in front of the rotor Get this brake system working first,then you should have enough room to finish the sprocket and chain. There are several sites where you can down load a better manual than a Clymer OR Haynes if need be. OPT
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
coldnorthpol
Jul 14, 2015 11:22 PM
coolguy420
Jul 10, 2015 01:17 AM
bikedad3
Jul 2, 2015 02:15 AM
