03 sportsman 700 stator has no voltage
Old 08-30-2011, 08:36 PM
bustedknuckles2003's Avatar
Default 03 sportsman 700 stator has no voltage
I have an 03 sportsman 700 with the ducati ignition. I determined the stator was sending .08 volts using a multi tester set on hold max settings. My first question should be is this the right way to do this test. If so i need to say i purchased a new stator from rmstators.com. Will this stator work with my ducati flywheel.because i am getting the same reading with the new stator. Wish i would have spent the additional 200 bucks and got the updated kit.would be grateful for any insight.
Old 08-30-2011, 11:34 PM
Welcome to the forum! Save yourself some grief!! Just order the kit,don't try to work around the Ducati system to save a few bucks,JUST replace it with the updated Kokusan complete ignition system! OPT
Old 08-31-2011, 11:03 AM
Thank you old polaris tech. You have helped me many times just reading your posts to others. Don not let that hard drive full of info,in your head, go to waist, share it like you have been.THANKS.
Jmuddin284
06-28-2017 04:59 PM
sweaver
11
08-18-2015 03:47 PM
kdg723
07-25-2015 01:20 PM
Schneider
07-24-2015 05:05 PM
Quick Reply: 03 sportsman 700 stator has no voltage
