97 Polaris Sport 400L 2x4
Old Dec 12, 2011 | 07:46 AM
Don't know what you mean,but the second pic is part of the outer balancer case and the bolt is the old fill plug that they left on the cases even when they added the dip sticks under the carb. OPT
Old Dec 12, 2011 | 05:28 PM
Medwayis's Avatar
Default Bottom end.
I think I now understand what needs to be replaced. the Entire bottom end needs to be replaced.
see pic. In the PIC, it's a whole bottom end that does NOT separate into 3 pieces.
bottomend.jpg picture by medwayis - Photobucket
However, Would it be safe to say I should replace the crank, Rod and piston to avoid future problems. ie, I know I have to replace the counter balancer and the gear that is to the left of it.
What do you suggest?
Old Dec 12, 2011 | 06:52 PM
Look up your model at Cycle Parts Warehouse, it will show the engine cases plus the outer case and the cost!Yes to the rod,piston and the destroyed counter balancer and crank gear are have to items! You don't want to have to go back in anytime soon,so a total rebuild is a must!! When you check the prices, a good used engine or used set of cases that you could rebuild,might be a better option! Either way a complete rebuild on a 400 will set you back some$$ OPT
Old Dec 12, 2011 | 07:29 PM
Medwayis's Avatar
Default Parts
If that is the case.. where do I find used set of cases.
Old Dec 12, 2011 | 09:05 PM
  #15
Oldsman67330's Avatar
I usually have the best luck on ebay finding used polaris parts, sometimes it might take a while to find what you want for what you want to pay for them, but eventually I end up finding what I need for a decent price.
Old Dec 22, 2011 | 06:48 PM
  #16
Medwayis's Avatar
I think I found a pair.. Please verify if this set will work on my machine..
Polaris 400L 400 L 2x4 ATV Engine Crank Case 94 1994
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
thanks..
Old Dec 22, 2011 | 07:09 PM
  #17
Yes they will work,but check the condition of your outer engine case that houses the stator assy. If still a little confused look up Cycle Parts Warehouse and the complete engine breakdown. There are a total of THREE cases! OPT
Old Jan 9, 2012 | 06:00 PM
  #18
Medwayis's Avatar
Got the covers off, still do not know where the shavings came from. See Pics..
behindwaterpump001.jpg picture by medwayis - Photobucket
behindwaterpump004.jpg picture by medwayis - Photobucket
Any idea's??
Old Jan 9, 2012 | 07:36 PM
  #19
Just use a magnet! If it wont pick any of the shavings up they are all from the case. If it picks up any steel shavings,then you need to pull everything apart to find out if it's a bearing,etc that may have caused the problem. OPT.
Old May 17, 2012 | 02:38 PM
  #20
Medwayis's Avatar
Question Posible new engine.
Well I gut'd the entire enge, Did not find the culprit that caused all this damage.
However. I do have a question. I found this Polaris Indy 400, Engine
It's a 400 - 2 Cyl engine block - complete. Could I mount that in my 97 Polaris Scrambler? I can't seem to find or see the motor mounts.
Any Ideas fellas....
Cole Hadden
Jun 15, 2025 09:05 AM
RickyMac
Mar 5, 2016 07:27 AM
1988josh
Ask the Editor
Jul 16, 2015 09:43 PM
John Boy
Jul 13, 2015 11:16 AM
black_thunder
Jul 9, 2015 05:58 PM
