polaris Hawkeye no spark...please help diagnose..
Old Jan 11, 2012 | 05:04 PM
  #21
mccostlin's Avatar
well I found it, the drum for the starter clutch has come loose from the shaft. all the rivets that held the drum to the shaft came out so i need a new drum/shaft.
should there be oil in the starter clutch area? when I took the shaft/cover off the starter clutch a little oil came out.
Old Jan 11, 2012 | 06:22 PM
  #22
Look up the ENGINE CLUTCH at Cycle Parts Warehouse on your model and you will see that the inner bearing and shaft are lubricated,but has a seal stopping any oil from seeping past the the outer drum and clutch shoe! The breakdown will show the parts you need and explain better than I can! OPT
Old Apr 20, 2012 | 10:18 PM
  #23
jasonn3's Avatar
Default What did you do to fix spark???
Help WHat did you do to fix your no spark problem?? I am getting the same thing as you with my polaris Hawkeye you can text or call me 816-213-4137 thank you so much Jason
Old Jun 10, 2012 | 01:22 PM
  #24
Saskyrider's Avatar
I'm having the same problem as well with no spark... what did you end up doing to fix it?
Old Jun 10, 2012 | 03:58 PM
  #25
Sometimes people don't post the results of what they've found. Don't know if this is free pdf or not, but see if it's what you need. POLARIS SERVICE REPAIR MANUAL ATV HAWKEYE 300 2×4 4×4 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 « True Service Manual OR here: http://www.imarksweb.net/book/free+m...laris+hawkeye/ OPT
Old May 2, 2013 | 10:34 AM
  #26
mccostlin's Avatar
I had a new aftermarket CDI box, I bought a genuine polaris CDI and it fired right up.... go figure....
Old May 2, 2013 | 02:20 PM
  #27
Now we know! That's what I asked you on the second page on the cdi...... I've had numerous complaints on non oem parts on the little ones causing problems.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Sportsman850
Jul 31, 2015 04:25 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
