rough idle
Old Dec 31, 2011 | 04:15 PM
hersh39@yahoo.com's Avatar
Default rough idle
I have a 1999 polaris sportsman 500 my problem when at a idle and in neutral if you max thumb throttle engine will bog down and miss like crazy but still stay running it will also back fire through the tail pipe. if you hold throttle all the way for about a min the engine will pick up and idle fine . then die maybe carb problem need some advice
Old Dec 31, 2011 | 05:18 PM
Welcome to the forum! If you can pull the valve cover and check the exhaust cam lobe(or lack of one if it's ground down!) sounds like the same old soft cam problem from all the 96-2000 model 425 and 500 engines! Not trying to sound harsh,but this is a common problem! Especially the popping back! They usually will crank and idle good,but wont accelerate. Plus you can check some back posts on this. If it happens the cam is fine,then could be just needing a good carb clean or rebuild? Just pull the valve cover and give it a good look,plus valves set at .006! Keep us updated. OPT
Old Jan 1, 2012 | 06:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
simple thing would be a dirty carb. not so simple is what opt mentioned, which they have been known for, is the bad cam.
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
