I give up Help!
Old Mar 28, 2012 | 08:22 AM
scootergptx's Avatar
Supersock
Hired Gun!
Originally Posted by Nltocean
Silly question: Why was your bike upside down??? Did it JUST start doing this after being upside down?
Yeah, that could kinda change the whole outlook.
Old Mar 28, 2012 | 08:23 AM
Supersock
Hired Gun!
Also, dry rotted carb? Boots as well? That could be your issue there. Crack in the boot is letting too much air in. But that would also change the spark plug color if you did a chop test.
Old Mar 28, 2012 | 08:24 AM
Can't figure it out!'s Avatar
I apparently thought I was 20 again… It did start doing this shortly after It was upside down… I think the whole intermittent thing has got me all turned around… Or… upside down…
Old Mar 28, 2012 | 08:25 AM
Nltocean's Avatar
ALSO, is your temp gauge working properly?
Does your fan kick on while you're riding? (Try starting it and revving it in your driveway a few times, let it idle a bit, revv it not hard tho, ...and see if your fan kicks on)
I've replaced three fans on the 05 500 and 08 400 once.
Old Mar 28, 2012 | 08:30 AM
  #15
Nltocean's Avatar
Agreed!!
Old Mar 28, 2012 | 08:36 AM
  #16
Yes, the fan does cycle as advertised, the Temperature gage is working properly, I’ve had the plastic off and on, on this machine so many times I’m thinking of putting Velcro on it.
I’ve chased down bad electrical connections cleaned/degreased and gooped with dielectric grease
I’ve changed and re gapped the plug
Cleaned carb.
Checked and serviced battery
Timing is good….
I know I’m missing something simple, I think I’m going to swap out that air breather boot, just seemed too simple..
Old Mar 28, 2012 | 08:48 AM
  #17
Nltocean's Avatar
VELCRO!!!
I'm awaiting new plastic to be delivered today for the 05 500 .... If they can't keep it between the ditches and part way on the trail, I'm gonna make them start replacing parts and doing the maintenance work themselves!!
You can get the carb boot and breather boot for under $25 on Ebay. Honestly, tho... I'm with Scooter on this. I'd replace that boot and see how it goes.
Old Mar 28, 2012 | 08:50 AM
  #18
Supersock
Hired Gun!
With it running, spray some carb cleaner on the boot and see if the rpm's go up.
Don't over spray it though.
Old Mar 28, 2012 | 08:51 AM
  #19
Cool guys, I will do that tonight... Got that stupi Job thing today... Gets in the way of a lot of things. I'll keep you posted. Thanks again!
Old Mar 28, 2012 | 08:55 AM
  #20
Nltocean's Avatar
No prob, keep us posted!!
Sassinm1
Sep 30, 2015 04:23 AM
Sep 30, 2015 01:37 AM
woodthings
Sep 25, 2015 05:58 PM
jankerstien
Sep 21, 2015 03:09 AM
Minimod
Sep 10, 2015 08:03 AM
