Reverse wont work Polaris trail boss 330
Old Sep 16, 2012 | 04:18 PM
Cewdy's Avatar
Default Reverse wont work Polaris trail boss 330
I put this in the other forum by mistake. when I pull the shifter into reverse I can feel it shift but when I try to move, it acts like Im in neutral. Surely its the transmission.
Old Sep 16, 2012 | 05:34 PM
Check the linkage assy and the shift lever (belcrank) on the gear case to see if it's stripped. If every thing is tight and runs in forward gear,then it could possibly be internal gear problems. Plus are you pushing the reverse override button to allow full power to reverse? Could be as simple as a reverse limiter problem.OPT
Old Sep 16, 2012 | 07:55 PM
Cewdy's Avatar
Thank you so much for your input. Also I apologize for double posting the topic.
txkevin
Sep 21, 2015 02:02 PM
Dylan.11
Utility ATVs
Jun 4, 2015 03:58 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
