Carb leaking gas out drain hose.
Old Sep 24, 2012 | 12:26 PM
lov2hunt's Avatar
Default Carb leaking gas out drain hose.
I have a 2001 Polaris 500 HO atv. It ran as if it was flooding or getting overloaded with fuel and then stop running. Now it will not start and gas is leaking out the small 1/8" drain/over flow hose coming from bottom of carb. It is leaking or actually almost running out all the time, even when the atv is off. Even with the gas valve on the left below the tank turned to the off position. Is this a fix I can preform or must I have to take it to an ATV Shop?
Thanks.
Old Sep 24, 2012 | 12:44 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
stuck needle / float-
take the carb off and give it a good cleaning.
you can try tapping the side of the carn to un-stick the float, but it probably really needs a good cleaning...
Old Sep 25, 2012 | 03:31 PM
lov2hunt's Avatar
Default Carb
Thanks, I'll give that a try.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Unzzy66
Jul 11, 2015 10:01 PM
Sjrpp
Jul 5, 2015 09:04 PM
