stripped threads on oil return hose
Timeserts are the best to repair damaged threads,but the cost of the kit along with different size inserts are prohibitive to most people for a one time use.Helicoils are the second choice and have been around for years and less costly,but not as strong a repair as timeserts. But since you probably won't be pulling this fitting on and off a helicoil should be ok. Just up to you on this. You might check some shops or machine shops as to costs on timesert repair. Might be worth the call. OPT
