2003 trailblazer sky revs when started
Check that your carb slide is not binding and does go all the way down and hits the idle screw OR if you have removed the slide for any reason check that you have it positioned properly on the slide cutout and inner carb slide guide. Also any air leaks around the base or head gasket,crank seals leaking,leaning out the fuel mixture,could be causing the high idle. Plus just remove the fuel line and check that flow is good also to the carb. Plus could be internal carb related problem,partially stuck float arm,etc. Several things that could be the cause. OPT
