sportsman 500 won't start
Old Jul 11, 2013 | 04:08 PM
poorfarm's Avatar
Then it's entirely possible the kill circuit in the cdi itself is bad causing the problem. If you know the ignition switch is ok,and since you replaced the left switch this is probably the case. I've had this happen before,some customers ok'd a new cdi,other said that they would just "choke it down" to kill it so they could avoid the expense of a new cdi..
the ign switch has 4 wires im guessing 2 red are power and other 2 are kill
Old Jul 11, 2013 | 04:18 PM
Black wire is the kill wire and ties into the cdi black wire along with the emergency kill circuit black. Just down load the 1996-2003 or the 2001 Sportsman 500 pdf and look at your year model wiring schematic. Can help you diagnose the problem. Index of /ORV Manuals/Polaris/Sportsman/1996 - 2001
Old Jul 11, 2013 | 04:45 PM
poorfarm's Avatar
thanks was going to get ohm meter and tone the wires and switch
Old Jul 12, 2013 | 08:46 AM
Keep us updated..
Old Jul 18, 2013 | 06:25 AM
  #15
poorfarm's Avatar
Default no fire
ok took left side controll off the on off start switch
burnt resistor on back side
on off key switch shorted
replaced both apparently power from key switch shorted back to on off switch how it didnt get theother parts dont know but got fire now
Old Jul 18, 2013 | 08:27 AM
  #16
Can happen! I've had to replace both the left control switch and ignition switch at the same time also. Sometimes hard to tell which one was the original problem,an ignition switch short,or a short in the left control switch which can then short out the ignition switch. Glad you posted your findings.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
