Speedometer Doesn't Work
Old Apr 14, 2013 | 12:29 PM
You will see the inner part of the housing turn if you jack the rear wheel up and turn them!If the inner part doesn't turn,normally the key has broken. Plus check the cable out now that you have it off.
Old Apr 14, 2013 | 12:38 PM
Axton's Avatar
I got up under the fourwheeler and shined a flashlight inside and didn't see anything?
Old Apr 14, 2013 | 12:43 PM
The wheels have to be turning for the adapter inner part to turn!! If you don't see it turn remove the three bolts holding the adapter to the tranny and pull it off! Plus can you turn the speedo cable??
Old Apr 14, 2013 | 12:46 PM
Axton's Avatar
Looks like there's an issue then. Nothing turns... Should i take it off and look at it?
  #15
Axton's Avatar
Yes, sir!! I'll take it off now. Be two seconds.
Old Apr 14, 2013 | 12:56 PM
  #16
1/2" bolts,plus will have a rubber grommet behind the adapter.
Old Apr 14, 2013 | 01:01 PM
  #17
Axton's Avatar
Ok, i took it off. Pain in the ***! Anyways, i took it off and the pin was stuck and it has a BUNCH of greasy black stuff. (Oil?) I took the pin out of the transmission and put it back into the 'key'.
Old Apr 14, 2013 | 01:03 PM
  #18
Axton's Avatar
  #19
Will the key while in the adapter turn? The pin you are referring to is the KEY! If it does turn, reinstall the adapter plate to the tranny and get a new cable if it's frozen or rusted.
Old Apr 14, 2013 | 01:09 PM
  #20
Axton's Avatar
Oh, thanks! Didn't know that.
Anyways, Nothing's wrong. It now turns. It seems like nothing is broken, only mis-aligned.
