00 Polaris Sportsman 500 clicking not drive belt
Old Sep 8, 2013 | 05:53 PM
highplainsdrifter's Avatar
Default 00 Polaris Sportsman 500 clicking not drive belt
I have a 2000 Sportsman 500 it has over 1500 miles now 700 since last belt replacement. I was riding up a hill in low gear and clicking sound started in the Clutch cover. I figured it was a drive belt issue and nursed it 8 long miles back to the trailer. Got it home and pulled the cover to discover the belt is ok but the front clutch started rubbing on the cover. I am sure this has been posted before but after two hours of reading I am still stumped. Help and guidance would be appreciated.
Old Sep 8, 2013 | 09:45 PM
You can try to adjust the small "L" bracket at the bottom of clutch backing plate to see if helps move the cover out a little. If this doesn't help it could be the cover has gotten hot and warped allowing the clutch to rub the cover. This was a common problem from the early days up until about 2008 when they went to the over size covers.http://forums.atvconnection.com/pola...ml#post3208811
whitty
67
Feb 24, 2021 02:52 PM
Larry S
Jul 4, 2015 12:54 PM
nature violator
Jul 3, 2015 08:40 PM
yellowpolaris
Jun 21, 2015 11:13 AM
Joeg
Sep 27, 1999 11:53 AM
