...at wits end!!!!!
Old Oct 14, 2013 | 12:39 PM
  #21
Originally Posted by mick mcleod
...and also I am not sure if I mentioned it b4 in any of my posts but the strut was damaged when the bearing failed.The inside of the hub,lets say between the oil seal and cv boot clamp was marred but I ground it down with a dremmel tool,but the machined part(bearing race?) was un-damaged.But I am still thinking that all the little things have added up to a bad coil. i.e. hub ran dry,bearing failure,extreme heat and so on
I get the feeling I am beating a dead horse here.
I have read your post about replacing just the coil and think I could mange it,but living up here in Canada it is still cost restrictive to order the coil,shipping is the killer.So i guess its 3 wheel drive for awhile until budget allows or if the price is right on a used assembly I might try it also,but it would have to be a real good low price
If you ran this hub dry and had damage on the inside of the strut,then you've probably done some damage on the outer part. It doesn't take much to screw this strut up especially if there is any wear on the thin inner machined pole of the strut. I've seen this happen and some would still have problems holding the armature plate even with new seal sleeves and awd coils.You could be beating a dead horse as you say..
Old Oct 14, 2013 | 12:51 PM
  #22
mick mcleod's Avatar
Well with all your help I think we can close this case.Its crazy that on a machine that is meant to be exposed to rough teerain would have such strict tolerences on the front end like this.I guess another reason they went with the centralized system,but I am sure it has its weakness' also
Old Oct 14, 2013 | 01:05 PM
  #23
...and with that being said do you have any idea of the years and models which used the same strut,just incase i decide to go that path
Old Oct 14, 2013 | 01:13 PM
  #24
Haven't checked myself as to which year models can interchange,should be a few as they standardize a lot of parts for different machines. You can check here on all the different models and years.Browse
Plus I've found a damage strut pic with an inner pole ground down,but the pic isn't the greatest.Look at the thin outer part and how it widens from being ground down by the plate.
Mar 22, 2016 09:55 AM
j.graul84
1) Engine problems..
Nov 6, 2015 08:42 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Micky
Mar 12, 2002 08:15 PM
Kevin1422
Mar 8, 2002 01:32 AM
