No Electrical power 2001 polaris magnum 325
Check your connections but sounds like the main 20 amp circuit breaker's probably corroded inside the sealed pouch.Sends power to lights,for starter,etc. Located up from the battery usually tucked up under left rear fender area. If it doesn't have 12 volts on wire going in and out of the pouch,slice the pouch open and check it out. Cheap part available at almost all auto stores. If that's the problem seal the pouch up with silicone or electrical grease and taped it up after you replace it.
Big600twin
14
06-16-2015 09:30 AM
