dead atv
looking for a little help.
2001 polaris explorer 250 . died for no apparent reason.. sputtered , restarted a couple of times and that was it. changed three quarters of the carb,,, removed ,cleaned, gaped spark plug,,, new battery..
still will not start....
it did run fine last year
well thank you for the tip,, there was no spark , tried another spark plug to make sure ,, again no spark ,, so if you could lead me to the next step and if you think I could do it myself I would appreciate the help,,
A few things you can try are to pull the plug cap and see if you have spark with the bare wire against the head. If you do have spark,the plug cap resistor is bad. If it still doesn't have spark,pull the black lead from the reverse limiter module under the front panel.Limiter is the module on the left,the only one with a black wire.If still no spark,pull the black kill wire from the cdi module and see if it has spark. If it doesn't you'll need a manual for further tests. The Explorer 250 was only made a couple years and manuals are hard to find. This one for a 2003 Trail Blazer 250 should have the same electronics.Look at the trouble shooting tests plus look at the wiring schematic.The schematic shows tests on the stator and coil and should help you narrow down the problem. http://gh-ftp.com/ORV%20Manuals/Pola...0%20-%20SM.pdf
cody500ho
14
Aug 14, 2015 05:03 PM
