06 Sportsman 700 wont shift into reverse unless engine off
Usually clutch/belt wear causing creeping is the main reason on not being able to shift,but usually affects all gear ranges. If just reverse is affected check the linkage assy along along with the shift belcrank on the transmission.If these are tight,then could be a gear problem behind cover #3. Items 5-7 or 19-22.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
