Magnum 425 water pump
Run it while looking down the rad cap hole with rad cap off. You will see if the antifreeze is circulating easy enough.
Also if the top and bottom rad hose are both firm and warm after warm up, that tells you its circulating.
That's how I found out I had a air lock in the system once. The bottom rad hose was cool and soft while only the top rad hose was hot and hard ,when both should be hot and hard.
This only happens if there is any trapped air in the water pump cavity. The air/coolant can get soo hot the impeller can melt.Same thing I found on water craft impellers that had air seep between the pump housing gaskets. Aluminum impellers would be melted down. Even stainless steel impellers would have holes in them from the super hot air. You have to replace the impeller,new gasket and keep the radiator cap off until any air is purged. Plus I've seen the impeller nuts just back off(probably weren't tightened enough) and impellers wouldn't turn with the shaft. Usually they'd get super hot if this happens. If the hot light isn't coming on,fan kicks on and off ok,no apparent leaks,then I wouldn't worry about it. Most thermostats aren't the problem if it's never overheated. Only replaced a couple that I can remember. One the rubber o ring around the thermostat was melted,the other one the small pin in the thermostat was coked,not allowing it to open fully.
jrooker6
04-23-2016 07:36 PM
BYC
09-25-2015 02:10 PM
Sw00p
09-24-2015 02:50 PM
