question
Old Jan 25, 2016 | 06:33 PM
trouttracker's Avatar
Default question
Can you take apart the lower part of the engine without taking the top end apart I need to replace the shaft my water pump impeller goes on.
Old Jan 25, 2016 | 06:43 PM
Keep forgetting what machine you have.. Anyway the answer is no,unless you have a 600,700 or 800. Those you can replace the oil pump shaft with tearing the whole engine apart.Normally they don't go bad,people usually bend em replacing water pump seals..
Old Jan 25, 2016 | 07:08 PM
it is a 425 and the threaded end to hold impeller on broke off unless you have another idea how to connect the impeller
Old Jan 25, 2016 | 07:11 PM
Oh man... Bummer.. Nope,don't have a better idea for this one. Oil pump shaft works the water pump also. You have to split the engine cases. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse A lot of work for a 60 buck shaft. I've only had to replace them when people went crazy on replacing water pump seals with out the "tool" needed and bent them.
Blueoval78
1) Engine problems..
Jan 26, 2016 09:01 PM
Avery Griffis
Jan 26, 2016 12:52 PM
JoeNewBee
Jan 25, 2016 09:44 AM
mikesjunk
Jan 3, 2016 07:16 PM
