1996 unusual electrical problem pls help
Old Feb 24, 2016 | 03:45 PM
Mattirons76's Avatar
Default 1996 unusual electrical problem pls help
First problem I have a 1996 Polaris sportsman 500 sometimes will not turn off then sometimes it will. The other problem is I have no spark when using the starter button but when using the pull rope I have spark with the key ignition in the off position but the switch on the on position and it will start. When the atv won't shut off the motor only has about half the power. I replaced the stator and pick up coil. Any help would be great Thks
Old Feb 24, 2016 | 06:35 PM
Sounds like a problem that several people have had. It would start with recoil,but not electric start. First off make sure the battery is up to snuff then you might want to check the air gap between the pick up coil and the magnetic tab on the flywheel even though it's new. Should be between 0.16 -.040. Closer the better. You can sightly "tap" these mounting brackets inward or enlarge the bracket mounting holes to allow it to move closer to the flywheel. This I would do last if all other checks fail..Plus look over this post from a member that experienced the same thing. no spark to plug when using electric starter - Page 3 - ATVConnection.com ATV Enthusiast Community People also over look the the left control switch. Spray some electrical contact cleaner in the crevices and work the switches,over ride and starter button. Dirt,moisture can can get into the brass contacts and cause problems. Plus follow this wiring down into the terminal board and check connections. Plus test that the emergency kill switch works,if it doesn't trace the black wire from the cdi,ignition switch and left control switch where they plug in to the terminal board. May be a problem there. The cdi itself can have internal problems on the black kill wire also. Doesn't happen often,but if you rule out a left control switch or ignition switch and its wiring,it's possible the cdi is the problem on not being able to kill it. Hopefully with these things to check out,you'll be able to find the find the problem.
spacex
21
Jan 18, 2016 07:19 PM
rider
Dec 19, 2015 07:46 PM
crkola
Dec 11, 2015 01:47 PM
SlickRick16
Dec 6, 2015 08:26 PM
Matthew30
Nov 28, 2015 12:32 PM
