Wires on front diff broke !
Old 03-05-2016, 09:11 PM
chuck1177's Avatar
Default Wires on front diff broke !
ok so what's the fix for a broken wire on the front diff ? It's a 04 sportsman 700 efi and the wire broke flush on the diff cover ! Am I gonna hafta replace whole cover or is there another fix for it ? Thanks
Old 03-06-2016, 02:23 AM
Only alternative if the wiring is broken flush with the case to where you can't splice it is to pull the diff,pull the cover and see if you can repair the wiring from the coil up out of the cover. While you're there I'd check the armature plate and roller cage. Simpler to just update the roller cage at that point. http://www.ebay.com/itm/Polaris-Spra...BVgsq~&vxp=mtr
Cummins Driver
02-22-2016 09:45 PM
Dragginbutt
02-20-2016 02:42 PM
Snky
02-08-2016 07:13 AM
jgar
02-07-2016 08:17 PM
amalota
02-05-2016 01:45 PM
Quick Reply: Wires on front diff broke !
