hard shifting
Old 05-03-2016, 10:48 AM
bulldog777's Avatar
Question hard shifting
i own a 2006 polaris sportsman 700 efi im having a problem with hard shifting also the machine creeps when put in gear i need help
Old 05-03-2016, 03:07 PM
Creeping,hard shifting go hand in hand. Usually it's the front clutch one way bearing that needs the fiber and metal washers replaced.A lot of times if the washers are worn,the belt can walk over and touch the inner sheath of the drive clutch. This just puts pressure on the driven clutch,causes creeping in gear and hard shifting.Worn belts,clutches out of alignment can cause similar problems or add to it.Look at these posts on the the same thing,but on a Sportsman 500. https://atvconnection.com/forums/pol...-creeping.html Plus here's the parts mainly responsible for creeping plus possibly a worn belt. Items #1-4. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old 05-03-2016, 06:00 PM
bulldog777's Avatar
Default hard shifter
thanks OPT ill check all of that info & get to work on that thanks again bulldog777
thl1222
02-29-2016 08:09 PM
TraxxasBeamer
02-27-2016 08:47 PM
Outdoorsdrew
Technical and How-To Articles
02-14-2016 06:56 PM
amalota
02-05-2016 01:45 PM
amalota
02-05-2016 01:35 PM
Quick Reply: hard shifting
