need some opt knowledge!
Old Jul 20, 2016 | 04:14 PM
1ArmBandit's Avatar
took it back apart, chain seems good BUT
when i go to put it TDC, the motor seems like it doesnt want to line right up, like its going over a lobe in the middle of it, my sprocket doesnt line up..heres a pic of where it "rests" when i have the flywheel in a very close ballpark of TDC..its either here or there, never feels like i can get it right on, like its off a tooth maybe, i had it lined up last time i was in there..i thought..(trying to get more input before i take the flywheel off and re time it...could/can it run like this since i did a head gasket last year???
Old Jul 20, 2016 | 04:16 PM
1ArmBandit's Avatar
Old Jul 20, 2016 | 04:41 PM
1ArmBandit's Avatar
heres another BUT lol....when i took the recoil off the starter bendix? was still sticking out on the flywheel..when i got it out it seems to retract fine and all...could that be the culprit..the battery was dieing at the end so maybe it just stuck this one time and has nothing to do with it
Old Jul 20, 2016 | 04:50 PM
If the bendix has a weak spin out and return,just replace it as cheap as they are.. On the cam timing look at this guys pics as a refresher. If you can't line the plated links up with the lower crank sprocket and case mark and the two dots on the cam sprocket correctly,then might be time for a new cam chain.https://atvconnection.com/forums/pol...ml#post3305250
Old Jul 20, 2016 | 04:54 PM
  #15
1ArmBandit's Avatar
chain feels good and last time i did a head gasket, it all lined up...is it possible that it still runs great in between click clacks with it being out of time??
Old Jul 20, 2016 | 05:03 PM
  #16
If cam timing is slightly off it's still possible to run ok but doesn't explain the noise you're having.Hope it had something to do with the bendix. If not,then you may have to dig deeper.
Old Jul 20, 2016 | 05:07 PM
  #17
1ArmBandit's Avatar
bendix first it is then...and this could go on for a few rides without fn up anything else like the starter? making sure becuase ive noticed it the last cpl rides
Old Jul 20, 2016 | 05:18 PM
  #18
If in doubt on the starter and bendix get em both.. Cheap on ebay or here.DB Electrical - Sportsman
Old Jul 20, 2016 | 05:30 PM
  #19
1ArmBandit's Avatar
gonna order it just in case, it was still on the flywheel and i can see where it was rubbing so that will be forst step...get back when i know! thanks for the input!
Old Jul 21, 2016 | 02:09 PM
  #20
1ArmBandit's Avatar
Is Plus have you checked to see if the slotted nut at the lower crank sprocket might have backed off and grinding up against the back of the stator plate? This noise can radiate upward and can confuse you as to where it's coming from..
exactly right on, sucker is just spinning freely...ty opt! i was about to just put the new bendix in and call it but i knew the timing was off....
so im thinking the nut backed as far as it could go and the lower spocket moved over enough to skip up the timing?????is that plausible?? if not then i may have to get even deeper....
