need some opt knowledge!
Old Jul 21, 2016 | 02:34 PM
  #21
1ArmBandit's Avatar
another ? ..can i set timing without popping everything off again, like if the key is at 12 and the cam sprocket is centerlined, can i assume its TDC? i really dont wanna tear the cab off again lol..its hot outside!
Old Jul 21, 2016 | 05:05 PM
  #22
See if the woodruff key is broken and if the sprocket has moved. That would throw timing off that you show.. Once back together just use the plated links in the pics on timing up the cam. Use medium(blue) locktite on the crank shaft threads when you tighten the slotted nut and you shouldn't have any more problems.From the factory NO locktite is used on the threads,but should have been.. Even though the slotted nut is reverse threaded and you wouldn't think it could back off since the engine runs clock wise and the force should keep the nut tight, they can back off and I've seen it happen several times. Woodruff key #22.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jul 21, 2016 | 05:26 PM
  #23
1ArmBandit's Avatar
my main ? is, do i have to take the rocker cpver off to time it, or can i assume its TDC when the cam sprocket is lined and the key is at 12?...i really dont wanna pull all that off if i dont have to
Old Jul 21, 2016 | 06:36 PM
  #24
Problem is in most cases if the slotted nut backs off the key gets worn or breaks especially if the sprocket has moved. Plus check the lower sprocket itself. If the channel for the key is wallowed out the lower sprocket will need replacing. Easier now since you have the stator off to do it right.. Get a new key,lower sprocket if necessary,then just pull the tensioner and use the plated links to align the lower crank sprocket mark with the case mark and the two plate links on the cam sprocket. Then it's timed right.
Attached Thumbnails need some opt knowledge!-20151028_185153_440eb6165fcb163313986c5b8761342e4ad20e90.jpg
Old Jul 22, 2016 | 08:53 AM
  #25
1ArmBandit's Avatar
cant find the manual i downloaded grr...im hungover and cufused lol..when i stumble out and its time to time this sucker, the key should be at 12 o clock or centerlined with the cylinder..like 2 o clock??? meehh im up too early :P
Old Jul 22, 2016 | 08:59 AM
  #26
Key slot should be somewhere around 12 o'clock position,but again the most important thing is the mark on the lower crank sprocket and the case mark must line up,then just install the one plated link on this sprocket tooth,the other two plated links on the two dots on the cam sprocket and it's timed.. Simple procedure. Just look at these pics again when you sober up.. https://atvconnection.com/forums/pol...ml#post3305250
Old Jul 22, 2016 | 09:01 AM
  #27
1ArmBandit's Avatar
i looked at that post earlier and it looks like his key is not around 12, but like around 2?
  #28
1ArmBandit's Avatar
or centerlined, with the jug..maybe its his camera position..ill just go by the case mark and sprocket mark
Old Jul 22, 2016 | 11:25 AM
  #29
1ArmBandit's Avatar
so after a good head scratch i took a look and am determining that it actually indeed IS in time....i was under the assumption the key was supposed to be at 12 o clock if you look straight at it...its more like 2 o clock lined right up with the cylinder...looks timed to me? marks line up, cam looks right..right?
Old Jul 22, 2016 | 11:54 AM
  #30
Just turn your head to the right and everything will look straight to you.. Yes the engine is at an angle,the key slot also. Main thing key and sprocket looks ok,lower timing mark is on the money and the cam sprocket alignment pin is center of the head. Again you have to turn your head for it to look right. Loctite the shaft threads,install the slotted nut then the stator plate, flywheel,recoil cover and see how it does.
