Need help with timing on a 98 sportsman 500
Old Aug 29, 2016 | 04:55 PM
  #31
Originally Posted by 98Sportsman500
Random thought any other test like compression that will give any confirmation of cam probably not as it's an exhaust lobe issue huh
55-95 psi compression on average because of the decompression device. Some machines may show a little higher.
Old Aug 29, 2016 | 05:13 PM
  #32
98Sportsman500's Avatar
Trying to think about it in terms of the cam compression will test good even though exhaust lobe is worn is that accurate
Old Aug 30, 2016 | 12:45 AM
  #33
1ArmBandit's Avatar
a bad cam would have no effect on a compression check
Old Aug 30, 2016 | 07:35 AM
  #34
Correct.. You can have a flattened lobe and still show within range because of the decompression device.
Old Aug 30, 2016 | 09:29 AM
  #35
That's what I thought I am gonna bite the bullet and pull the cam and be done with this project lol details to follow
Old Aug 30, 2016 | 11:52 AM
  #36
You don't have to pull it.. Just a visual check is sometimes all that's needed if it's ground down bad enough. If in doubt measure the lobes and look at the rocker arm for scarring. Here's a bad one up against a new one.
Attached Thumbnails Need help with timing on a 98 sportsman 500-18dd9f98-ed85-43d9-b272-0c7d6905c4cd-411-0000002e1b093495_zps832eb542.jpg
Old Aug 30, 2016 | 01:38 PM
  #37
Sorry yah I meant pull the cam not the motor but I guess I could pull the rockers first and rotate the engine a couple time and see if I can ID the lobe or lack of a love
Old Aug 30, 2016 | 03:40 PM
  #38
That's what I meant too.. Just examine the cam.If the cam needs to be replaced you can replace it with the engine still in the frame.
Old Aug 30, 2016 | 03:54 PM
  #39
Absolutely thanks for all your excellent advice getting to this point
Old Oct 2, 2016 | 04:26 PM
  #40
Well OPT so just went ahead bit the bullet and finally put a new cam in it to no avail still idles like a dream but when I give it throttle it bogs out with no gain in rpm as a matter of fact it almost stalls
