Need New RAD Hoses
Old Feb 17, 2017 | 10:09 PM
GregM's Avatar
I had to use the preformed for the bypass. The heater hose kinked on the by pass. I will try the wrap and see what happens. To check the fan I can just touch both connections togeather and the fan should come on after the temp is at normal temp, correct? I will get a new temp sensor as well Thanks again
Old Feb 18, 2017 | 07:58 AM
You can just have the key on and jump the two spade connectors and the fan should come on.If it doesn't then could be a ground problem or a fan motor itself may be at fault.
Old Feb 19, 2017 | 01:14 PM
GregM's Avatar
What type of radiator fluid should be used? I looked several stores for one compatable with aluminum but none listed or found.
Old Feb 19, 2017 | 02:14 PM
Many coolants are compatible with aluminum radiators. Prestone,Zerex,etc. 50/50,60/40 is ok to use.Most premixed coolants use distilled water and good for copper or aluminum radiators.
Old Feb 19, 2017 | 06:20 PM
  #15
GregM's Avatar
None of them listed aluminum so I was not sure so any 50/50 mix will work
Old Feb 19, 2017 | 11:57 PM
  #16
Just go for it... Engine coolant either in 50/50,60/40 has been suitable for almost all types of radiators and engine blocks for years. Plus most use distilled water so no minerals can cause problems.If in doubt get a gallon of this.
If money isn't a problem you can go for the specialized coolants.
Amazon Amazon
Or Engine Ice.
Old Feb 20, 2017 | 09:54 PM
  #17
GregM's Avatar
Update. Went ahead and emptied the rad with the drain and the whole drain came out. Checked the fan and it works so will put a new sensor in a little lower if I can find. What is the factory sensor setting 185? Ran all the water out and hot light did not come on. Will get the hose wrapped tomorrow.
Old Feb 21, 2017 | 05:21 AM
  #18
185 degrees fan come on,goes off at 165 degrees. 221 degrees on hot light.
Old Feb 21, 2017 | 03:13 PM
  #19
GregM's Avatar
Tried to find a sensor at oreillys & napa and no cross over. Found one at partzilla with part #4110189 Has anyone mentioned about finding one to cross over somewhere
Old Feb 21, 2017 | 03:14 PM
  #20
GregM's Avatar
Maybe we need to start a sticky for crossover parts
