07 sportsman 500 speedo
Old Apr 29, 2017 | 06:00 PM
Whitetailhunter8955's Avatar
Default 07 sportsman 500 speedo
Hi opt,
a month ago o bought a brand new speedo and have not had any problems. I went out to start the wheeler the other day and nothing lit up on the speedo... I pulled it out to check it and it seems everything is still plugged in. Is there s fuse that feeds that? Or a wire in that cluster that should have power that I can test? My brother has a 2010 and if his is the same speedo I will plug his in to see if it works.
thanks
Old Apr 30, 2017 | 05:57 AM
With the key off there should be a red memory wire that has voltage at all times. I'd check that first. The manual has a good series of checks also on the speedo connector pins and their functions.
Old Apr 30, 2017 | 06:52 AM
I wiggled the wire connectors under the seat by the fuel injector and the display came back in... corrosion in the connector?
Old Apr 30, 2017 | 09:23 AM
Just clean all the connectors and use some electrical grease and that should solve any future problems.
