New owner of a 2002 sportsman 700 and need help witha few questions
Old Jul 12, 2017 | 01:12 PM
If the other 3 tie rod ends are tight,you can get by with replacing just the one. Jack it and check for any play on the swing arm bushings and ball joints while you're at it also.
Old Jul 15, 2017 | 08:38 PM
joecrash13's Avatar
OPT I have a few more questions for you. Do you recommend any fuel cleaner/ treatment for the sportsman 700 and what fuel octane do you feel it runs at its best? Also I did install new odi grips on the quad but had to move the brake and throttle controls closer inboard about a 1/2''. Will I need to adjust the throttle cable or since it was working just fine I have no issue? Also seems like the old owner had jerry rigged a battery to the rear rack and I'm in the process of putting the battery in the correct position, So I have a question as to how the negative and positive battery cables are ran into the battery box? Any pics would be of great help. Any easier way to change the front brake fluid out without using the mityvac?
Old Jul 16, 2017 | 01:40 AM
My two cents either Marine Stabil or Star-Tron. Throttle slack at the thumb lever should be no more than 1/8" or the etc contacts can touch and cause hard starting or won't start unless you give it throttle. Mityvac is the easiest way but you can use shop towels to soak up fluid from the reservoir,top up with fresh dot 3 or 4 fluid and start bleeding the rear caliper first until the fluid is clear.Then move to the front right caliper then the left. Just keep the master cylinder full at all times. This video on a 2003 shows how the battery is mounted and cable location. Same as your 2002 model.
Old Jul 16, 2017 | 09:49 AM
joecrash13's Avatar
Thanks once again. what do you recommend for fuel octane? Also Any brand you prefer for rear wheel bearings?
Old Jul 16, 2017 | 10:17 AM
  #15
87 or 89 octane. Premium fuel you're just wasting money. Look at this site. Shows a lot of parts that can be used instead of oem parts and purchased at most auto stores,etc.http://apicdn.viglink.com/api/click?...d-m888094.aspx
Old Jul 17, 2017 | 03:41 PM
  #16
joecrash13's Avatar
Default Wheel bearing install
When you press out the old bearings, do you press the new rear wheel bearings in as well?? They were nice and tight pressing out, but I have since cleaned the hubs and rid of all the corrosion.
Old Jul 17, 2017 | 04:07 PM
  #17
You can press them in or what I did was simply put the bearing in the freezer,heated the hub with a propane torch and just dropped the bearing in. Then replaced the large snap ring.
Old Jul 17, 2017 | 09:10 PM
  #18
joecrash13's Avatar
Can you throw the hub in the oven too??? What temp do you think you will need???
Old Jul 18, 2017 | 05:54 AM
  #19
400 degrees in preheated oven for about 20 minutes or so while the bearing is in the freezer. Have a hammer and punch handy in case you need to seat the bearing further.
Old Jul 19, 2017 | 11:55 AM
  #20
joecrash13's Avatar
OPT thanks again for bailing me out. your infinite knowledge has saved my bacon once again. Now next question... What color wire can I tap into the ignition wire circuit to hook up a wire for the warn 2500 provantage winch? They say to tap to a wire when you turn the key to on or start so you can run the winch. The wire from warn is red, but seems like there are a few red wires in the ignition wire bundle? Thank you!
