Need a little help diagnosing AWD
The front right was about 25 ohms and it is engaging in AWD. However, to make it disengage I have to shift to reverse. Could this be a symptom of a worm armature plate?
The left side is not reading any ohms on my meter. I stripped the insulation off and cut the wires close the to hub to rule out a broken wire and still no ohm reading. It appears the coil is bad on the left side. Looks like one more parts order for me.
