2007 Polaris ranger 700
Old Mar 19, 2018 | 07:24 AM
Stevehayes's Avatar
Default 2007 Polaris ranger 700
I have a 2007 Polaris ranger 700 that is throwing 51 52 54 56 codes new fuel pump ,can't find any broken wires need tech help would like to ride
Old Mar 19, 2018 | 07:27 AM
Stevehayes's Avatar
I looked up the codes and it says problem with injectors I don't care to replace them just don't want to start throwing parts at it blindly any help would be greatly appreciated
Old Mar 19, 2018 | 08:36 AM
Look at this "sticky" post above this section on 700/800 efi problems.https://atvconnection.com/forums/pol...ap-wiring.html Injectors rarely fail(not that it can't happen) but most of the time it's wiring or connector issues. Wires may look good to the eye but they can be melted internally. Connectors may look good but pins can pull back and make erratic contact with sensors. You can sometimes wiggle the tbap or tps harness and if you notice an engine change,the problem may be there. Polaris supplied sensor harness repair kits that were junk. Same thin wiring and cheap connectors. From the sticky post came better repair kits from Otb.https://otbpowersports.com/products/ If the manual link I sent doesn't help and you can't trace it down to an individual sensor harness,the best thing to do then is let Digital Wrench try to find any problems. It can save you time and frustration on efi problems.
Radcliffe
Aug 31, 2016 08:21 AM
aprilandtai1220@gmail.com
Aug 22, 2016 12:34 PM
eyeowa
Utility ATVs
Aug 20, 2016 01:50 PM
thestig
Aug 12, 2016 12:24 AM
Aug 7, 2016 11:06 AM
