04 polaris 500 ho 4x4 atp
You have two thermal circuit breakers in plastic pouches,one is the main 20 amp circuit breaker and a 10 amp breaker is under the front panel for the fan. The 20 amp main circuit breaker should be along the harness up from the starter solenoid if I remember correctly on the Atp.If this breaker has corroded terminals it can trip the breaker and cause the speedo to blank out. Slice open this pouch and see if it need replacing. You can get it at most auto stores.Duralast/20 Amp metal circuit breaker (CBR210) | Circuit Breaker | AutoZone.com
