08 RZR electrical connections?
Old Jun 19, 2008 | 03:35 PM
JBarnes's Avatar
Default 08 RZR electrical connections?
I've got this new RZR and there is a grey plug hanging out on the right side under the dash. There is also a 9 volt battery terminal on the wiring harness located in the same area. I'm curious as to what that grey plug is used for and why are thos battery terminals in the harness?
Thanks, jerry.
Old Jun 19, 2008 | 04:27 PM
G.A.S.'s Avatar
The grey plug should be for computer connection for diagnostics from the dealer. Not sure about the 9V connector
Old Jun 20, 2008 | 12:11 PM
Hotdogmb's Avatar
would that 9v connector be there to power the units brain if the battery is disconnected??
Old Jun 20, 2008 | 12:40 PM
JBarnes's Avatar
I'm not sure, sure is curious why its there. Even the guys at the dealer weren't sure. Not something you typically see. But, I would guess you are right, it may be a way for them to power up the computer without having the key. Since the battery is protected with a solenoid if you don't have the key you can't power anything up.
Thanks, Jerry.
Scooter's Shop
Oct 9, 2015 02:09 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
johnny1982
Sep 13, 2015 07:41 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
lancemll88
Sep 6, 2015 03:03 AM
