cutting off
Old Dec 6, 2008 | 07:28 PM
Quailand's Avatar
Default cutting off
My 1999 ranger 6x6 runs great for 30 minutes, then it cuts off. If I leave it alone for a few minutes, it will start up? Please help!!!!!
Old Dec 11, 2008 | 11:41 PM
Default cutting off
<div class="FTQUOTE"><begin quote>Originally posted by: Quailand
My 1999 ranger 6x6 runs great for 30 minutes, then it cuts off. If I leave it alone for a few minutes, it will start up? Please help!!!!!</end quote></div>
When it quits running,pop your seat,disconnect fuel line from carb,turn key on and see if steady fuel flow from line. This is first thing I can think of. If flow is good,then check for spark,plug out and in the cap,grounded on head,crank over see if good spark (make sure fuel line back on and no gas around plug!!)
Old Dec 14, 2008 | 12:20 PM
tstroker's Avatar
Default cutting off
sure sounds like a fuel pump.
Old Jan 9, 2009 | 02:23 PM
tshoerichs's Avatar
Default cutting off
My 04 was doing the same thing. Lift the seat and near the top of the engine you will see a bunch of wires running along there; I'm betting one or more of those wires is rubbed through and shorting out. I had the craziest symptoms and I too checked the fuel pump, all kinds of things.
Alex G.
Sep 11, 2017 11:38 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Elkaholic
Sep 6, 2015 02:44 PM
