Biggest Mudlite on a Sp600
Old May 14, 2003 | 10:52 AM
NovaKaw650's Avatar
Default Biggest Mudlite on a Sp600
Got a buddy with a new Sp600. What's the biggest tire (preferably Mudlites) he can run with no mods on stock wheels?
And the biggest he could run with minor changes.
Old May 14, 2003 | 01:36 PM
V8s10's Avatar
The problem you run into with stock wheels is on the front the tires will rub the tie rod ends. I put 28x9-12 589s on my 700 on stock wheels but had to put one inch wheel spacers on the front for tie rod end clearance.
Old May 14, 2003 | 02:09 PM
NovaKaw650's Avatar
The 28's didn't hit the floorboards?
Old May 14, 2003 | 04:01 PM
Bill35's Avatar
You can run 26in tires without doing anything if you go with 27or28s youll need to lift it...
Old May 14, 2003 | 06:09 PM
V8s10's Avatar
It doesn't matter if it is lifted or not, with the stock rims anything wider than an 8 inch tire will rub the tie rod ends on a 600 or 700. I do have a little over one inch lift on my 700 and moved the floorboards back about 3/4 inch to clear the 28s and have one inch highlifter wheel spacers. Some people just put a stack of washers on the lug stud behind the wheel to space it out some, but I don't like that method and still the tie rod ends are so close to the tire the mud will probably tear the rubber boots off.
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
DeFox500
Jul 26, 2015 06:32 PM
traumajunkie
Jun 23, 2015 03:15 AM
