fouling plug
Old May 19, 2003 | 06:35 PM
ftwflh's Avatar
Default fouling plug
Your best bet is to invest in a manual.To check the choke on your carb is a good chore.But easy after you have the pics to do it. I think Your carb is different from what NCscrambler is thinking(if it is like the one on my 425)You have to pull the tank and take the diaphram off the top of the carb and lift the choke to half choke,inspect the air bleed hole.Loosen thelocknut on the choke and turn the adjusting screw in or out until choke plunger iss half way in the hole(half the hole is covered),put the choke all the way on(the hole should be all the way open),turn choke off and check for a small amount of free playat the lever before the plunger starts to move.Thighten up lock nut and put diaphram back together and everything else back on.
Old May 19, 2003 | 06:54 PM
NCScrambler's Avatar
Oops, thanks Ftwflh for keeping an eye on me, I just copied and pasted... My fault. do like Ftwflh tells you. Later
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
