Supertrapp Exhaust help
Old May 16, 2003 | 10:06 PM
bigmval's Avatar
Default Supertrapp Exhaust help
I had just put in The K&N Power kit and took her for a rip Wow what a difference. Now I will need new tires just to keep the power to the ground at launch. Anyways I was running 12 disks in the exhaust and finding it rather loud for the congested areas I was riding and wanted to try dropping it down to 8 disks to see what difference in noise and power I would see.
Thats when everything went to crap I broke one of the 3 screws used to hold the restictor plates in .[img]i/expressions/face-icon-small-sad.gif[/img] When I tried to grab with pliers to turn out the broken piece it is like a nut on the back side came loose because now all it does is wobble and spin.
I thought you took these things apart to repack so I figured I would pull apart and figure out how to fix. I can not pull out the core. I tried everything, putting the two good screws back in and pulling on them to no avail. I then removed the inlet pipe and tried to beat it out with a nylon bar and a hammer but no luck. Short of mangling pipe I could only get it to move 1/16th or less.
Do they come apart and if so HOW!!!! Any tips would be appreciated. I would hate to have to buy new exhaust for a broken screw![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old May 16, 2003 | 11:42 PM
ftwflh's Avatar
There should be a screw on the bottom of the silencer
Old May 17, 2003 | 12:54 AM
bigmval's Avatar
I did undo that. When I saw the screw I figured it should come out because what other purpose would this screw have other than to hold the core in the silencer.
I am just looking for some verification that I can seperate the core from the silencer before I continue to beat on it. Any tips on how to remove would be helpful.
Thanks for the response!
Old May 17, 2003 | 07:45 AM
ftwflh's Avatar
I will see if I can find the instructions from myy system and get back with you.
Old May 17, 2003 | 10:01 PM
bigmval's Avatar
Thanks for the effort ftwflh but I got it done, Just needed a bigger hammer. That thing was really stuck.
Thanks again
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
