Is Polaris 500 H.O. Reliable?
#21
#22
#23
I took most of your advice. I bought an 04 500 Sportsman. I haven't got to ride it but about 5 minutes. I guess I'll really try it out tomorrow. Since I've never owned a Polaris, is there any recommendations you all have for the first time Polaris owner. I don't know that much about these bikes. I ride on one particular rode that is about as rough as you can get. Should I use Low range in this area. It is not steep. Just big rocks and gulleys. Thanks.
#25
#26
You'll get the feel for using low. If you are pulling, pushing, or going through heavy mud. Also, if you are climbing around on those rocks. This will help on belt wear. There is no need to ride around in low gear, usually.
If you have any other questions, just ask.
Scott
#27
i agree, if you want to put around, pull heavy loads, drive through the deepest mudpits you can find, or climb steep hills, then use low range. when climbing hills, you can use high as long as you are moving before you get to the base of the hill. same thing in the mud, just depends how deep & gooey the stuff is. sometimes low works better & sometimes high. you'll get the hang of it in no time! let us know what you think of it after a few more hours of riding.
#28
Heck
I would look into the www.heelclicker.com web site. they make a clutch kit that does wonders for your bike. I have a 03 500 HO and put a heelclicker clutch kit in it and wow what a difference. The kit grabs the belt faster and puts more torque to the ground. By not slipping as much, that means less heat build up and longer belt life. I use low range much less now due to virtually no belt slipping. The best add on mod you can get for a 500HO . I hope you like your new ride.
Good luck
Rickster
Good luck
Rickster
#30
Been away 4 a few days, .. was interesting to see all the replies...
1st, congrats on your purchase.. I'm sure you wont be dissapointed. Is your quad reliable????.. hell, yes... for the nay-sayers that say you will burn a belt... doesn't ever happen unless you're in hi-torque situations at low speeds in high range. going thru mud/snow/bogs/muskeg @ low speeds, just put it in low range.... same applies to hill climbing... if you have a head of steam and head up the hill no probs, but if startin from the bottom at a stand-still... why not use low ???? easier on everything...
I've never burned up a belt and dont intend to ever.... hehehe.
Also the choice of quad depends on the type of riding you do... alot of the stuff we go thru is DEEP mud, with tricky side-hilling... i wouldn't EVER be able to get thru some of the stuff we do on a 5-speed quad... often we have to stand both feet on one running board and pull hard to keep the quad from flipping... How can you change gears or operate a clutch when your quad is nearly on it's side?
once again great choice..... I'm sure you'll enjoy
