oil injector pump bypass help
Old Jul 12, 2003 | 10:45 PM
lasermania's Avatar
Default oil injector pump bypass help
I have a 2000 trailblazer that i think the oil injector pump is bad on. I want to delete it and start premixing. anyone out there done this? Ive already tried to just diaconnect the cable, inlet and outlet, drain the oil and gas and then filled it with 32:1 but it barely runs. Any help would be appreciated.
Old Jul 13, 2003 | 12:25 AM
atv4bubba's Avatar
You need to buy an oil injection block off kit, you can remove the tank and oil injection mechanism is replaced with an aluminum post that goes in the crank and a plate covers the hole. HPD sells the kit, I think its around $19.
Old Jul 13, 2003 | 01:07 AM
lasermania's Avatar
Why do I have to actually remove the pump. Just unhooking wont work? What ratio do you run? HPD- what does that stand for? do they have a web sight?
Old Jul 13, 2003 | 02:01 AM
Cowboy35's Avatar
HPD stands for High Performace Designs and they are the best people to go to for polais atv accessories. I have many HPD mods on my 400 sport including the oil injection block off. The kit will come with instructions and is not bad to put on if you have some tools and mechanical experience. HPD's website is www.hpd-inc.com Hope I have helped.
Old Jul 13, 2003 | 02:45 AM
modquad's Avatar
Pre-mix at a 40:1 ratio.
Old Feb 22, 2004 | 11:22 AM
69camino69's Avatar
what do you have to do to get the pumpdrive gear out of the engine case, thank you very much
Old Feb 22, 2004 | 11:55 AM
ScrambleMe's Avatar
I ve seen your posts 69 but couldnt understand so I went out and looked at the one I removed.. dont know if its the same. but did you remove the two screws holding the the whole inner mechanism in?
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
