a few scrambler questions
hey guys a few questions for ya,i can slide my a-frames back and fourth about a 1/4 inch does that mean my bushing are gone?if so do ya recommend hpd's bushings?also i can turn about 1/2 inch before the tie-rod actually moves i guess i need new tie-rod ends?is either part covered under warrenty?im also wondering how many vent lines i should have hanging from the 4-wheeler?thanks for the replies
The HPD bushings can tighten things up. I would go over your steering components and make sure everything is torqued properly, then try to isolate where the play is coming from. Tie-rods are the normal culpret, but it never hurts to give the quad periodic, thorough inspections.
fordfaithful21
Dec 7, 2015 05:52 PM
Logan Collins
Sep 5, 2015 08:03 PM
