changing primary clutch springs
Old Jul 16, 2003 | 03:05 PM
mudslinger250's Avatar
Default changing primary clutch springs
I just ordered a new primary clutch spring for my Trailblazer and need to know how to install it. Any information you have to help me let me know. Thanks.
Old Jul 16, 2003 | 04:07 PM
CED's Avatar
CED
Remove the clutch cover,remove the six bolts that hold the plate on.Then remove the center bolt,the plate will then come off and you can replace the spring.Remember that when you put the plate back on there is an X on the cover that needs to be lined up with the X thats inside.If you do not do this the clutch will be out of balance.Hope this helps.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 16, 2003 | 05:26 PM
talonhawk's Avatar
Just one thing to add. That plate will be under some pressure from the
spring! Not much of a problem when you remove the spring but depending
on which spring you are installing, you might need some help pushing
the plate back on enough to get the bolt started!
Old Jul 16, 2003 | 06:55 PM
lovemud's Avatar
I use a wood broom handle to to stick thru the mechanism to hold it in place while tightning the bolts, just make sure it's not sitting on the spring.
Old Jul 16, 2003 | 11:33 PM
2manytoys's Avatar
Dont forget about the white plastic bushing that goes on the end of the center bolt. I have seen people forget this or misplace it.
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
ghost civic
Jul 27, 2015 03:15 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
