Fuel filter on 1991 Trailboss 4X4, help me find it!
I am trying to locate the position of the fuel filer, it isn't running all that great and stalling, and I suspect the filter. Can anyone tell me exactly where it is?
Thank you that's exactly what I was looking for. We just got this thing after we had a 125 breeze and I'm not too farmiliar with it. Now, after I've changed the fuel filter, I seem top have a coolant leak. At the end of the hose there is a plate on the block with 4 screwws in it. I think the gasket there is worn out. How hard is it to change that out?
Im not too sure. Hopefully someone with more experience with your machine will chime in. There are a lot of knowledgable people here with more experience with that than me. By the way, welcome to ATV Connection
That is the oil filter BigBad... The fuel filter, if it has one, should be #26 on this chart, which is up under the tank itself. I cannot tell which part of the cooling system you are talking about, so which number is the suspected leak coming from on this chart??
