help high speed shimmy
Old Aug 1, 2003 | 01:09 AM
Traildog's Avatar
Default help high speed shimmy
judging by the response here my guess would be "SLIME" settling and solidifiying to some extent. I had a shimmy a year or so ago, mine turned out to be a bad (out of round or out of balance) tire. The dealer replaced the tire and all is well.
My check is to securely support the quad on axle stands and with the engine running put it in gear and slowly increase the speed untill you get the wobble. Check the wheels and tires very closely and if you have a bad tire you should be able to identify the source.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
